Thanks for your reply.
I think your suggestion that KSTEP might be drawing too much current is correct.
I removed the J34 an J35 jumpers and connected the +5V power to the KSTEP (not connected to KFLOP) and the D2 LED blinks. In addition, the LED on the +5V power supply blinks. (By itself, the power supply looks OK.)
I don't have and easy way to measure the current, but there seems to be a problem on the KSTEP board.
Previously I down played the role of the static shock I received, but on reflection I think that may have been the cause for the failure.
- It was a large static shock--it almost felt like the shock from 120V current.
- It occurred to me that the several second delay between the shock and CNC stop might have been the time it took to empty a buffer.
In any case, I ordered a KSTEP replacement Friday and I'll see if that fixes the problem.
I've grounded the dust collection hose and ran a ground wire to the frame of the CNC in the hope that this doesn't happen again.
John
